laptop battery doesn't charge full issue
sylvia88
hi,guys and girls, i just bought a laptop a couple days ago, sadly to sya that the battery doesn't charge past 45% and then shuts down without any warning,. I am frustrated and wonder if i have got a dead battery? Any symptoms will indicator that your battery have suffer from failure? This happened spontaneously, quite literally. I received the notification from the computer when i am in the middle of working(I can't remember what exactly it said, but the computer shuts down later).
why my laptop is acting this way? Anyone know the solution to solve this problem? any help will be greatly appreciated.
In addition, if i got a bad battery and need a new one, where should i go to buy? Ebay is out of my consideration. my friend recommend me a website , but i have no idea if it is trusted by us.....
TheHumanBot
which website your friend considered you?
as you are saying it restarts it self could be problem with your motherboard.
faulty charger it could be only your adapter pin you know it gets bend from top and you have to struggle with it to make it charge.
