Help required for purchaing Cabinet
Varunnagwekar
Semi-Geek
Hi guys,
My question is a very simple one. All I need to do is buy a cabinet. But I don't know which ones are good and which ones to buy.
I have the following components
GFX card 4870 HD,
2GB ram,
3 Hard disks,
1 DVD writer
Sound card
Tugen SMPS (which is so huge compared to a normal Rs.300 smps!)
My budget is somewhere upwards of 2k but definitely less than 8-10k. If the recommended cabinet is really expensive, could you please also tell me why is it so and what are the features it provides?
I would really appreciate any help provided,
Thanks,
Varun.
