HELP Regarding Airtel EDGE in PUNE
kkg_mjh
well i want to know weather EDGE is available in Lohagaon area or not
coz i'm getting a very slow speed
can i get details where the EDGE services are available
and yes I've EDGE enablled phone (Nokia 6020)
Pathik
Google Bot
airtel sux.. Sometimes u get more speed in a normal area than an edge area.. Do u get an edge indicator like an E sign??
K
krazyfrog
Guest
None of the Nokia phones indicate the presence of EDGE. They just show 'G' in either case. If your getting slow speed, then there probably won't be EDGE in that area.
deepakchan
Troubleshooter
pathiks said:
well my e50 shows a E wen connected to an edge network..
Hey. Sorry I know this is off topic. But how is E50? I was planning to buy this phone but many reviewers said that it automatically answers some calls randomly on speaker and it is difficult to switch off the phone after that and you need to take out the battery to solve the problem. Are you also facing this problem?
