Help: Problem With Nero DVD Writer....
RoughGuy
Hi friends... im using Sony DVD Writer DW-Q28A KYS3. I use Nero 2 burn the disks. Recently im facing a problem. When ever i try 2 write the DVD's its giving the following error and stopping the burning process....
Code:
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15h
 (Nero Express)
Recorder:             <SONY DVD RW DW-Q28A>     Version: KYS3 - HA 0 TA 1 - 6.6.0.15
 Adapter driver:      <atapi>                   HA 0
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <SONY     DVD RW DW-Q28A  >Version: KYS3 - HA 0 TA 1 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral       : SAMSUNG SV2044D                  atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : SONY DVD RW DW-Q28A              atapi Port 0 ID 1  DMA: Off
CdRomPeripheral      : NERO    IMAGEDRIVE2     2.26  imagedrv Port 2 ID 0  DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q28A        E:   CDRom0
NERO IMAGEDRIVE2           F:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 503MB (515572kB)
Free physical memory: 163MB (167136kB)
Memory in use       : 67 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.9.2006
ISO compilation
9:17:14 AM	#1 Text 0 File Isodoc.cpp, Line 6314
	Iso document burn settings
	Determine maximum speed : FALSE
	Simulate                : FALSE
	Write                   : TRUE
	Finalize CD             : FALSE
	Multisession            : TRUE
	Multisession type:      : Start multisession
	Burning mode            : DAO
	Mode                    : 1
	ISO Level               : 1 (Max. of 11 = 8 + 3 char)
	Character set           : ISO 9660
	Joliet                  : TRUE
	Allow pathdepth more than 8 directories : TRUE
	Allow more than 255 characters in path  : TRUE
	Write ISO9660 ;1 file extensions        : TRUE
9:17:14 AM	#2 Text 0 File Reader.cpp, Line 127
	Reader running
9:17:14 AM	#3 Text 0 File Writer.cpp, Line 122
	Writer SONY     DVD RW DW-Q28A   running
9:17:14 AM	#4 ISO9660GEN -11 File geniso.cpp, Line 3309
	First writeable address = 0 (0x00000000)
9:17:15 AM	#5 Text 0 File Burncd.cpp, Line 3231
	Turn on Disc-At-Once, using DVD media
9:17:15 AM	#6 Text 0 File DlgWaitCD.cpp, Line 269
	Last possible write address on media:  2298495 (510:46.45, 4489MB)
	Last address to be written:             579199 (128:42.49, 1131MB)
9:17:15 AM	#7 Text 0 File DlgWaitCD.cpp, Line 281
	Write in overburning mode: NO (enabled: CD)
9:17:15 AM	#8 Text 0 File DlgWaitCD.cpp, Line 2477
	Recorder: SONY DVD RW DW-Q28A, Media type: DVD-R
	 Disc Manufacturer: TYG02 -
	 Disc Application Code: 64, Disc Physical Code: 193
9:17:15 AM	#9 Text 0 File DlgWaitCD.cpp, Line 447
	>>> Protocol of DlgWaitCD activities: <<<
9:17:15 AM	#10 Text 0 File ThreadedTransferInterface.cpp, Line 830
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 579200 (579200) = #579200/128:42.50
	    relocatable, disc pos for caching/writing not required/ required, no patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 579200 blocks [SONY     DVD RW DW-Q28A]
9:17:15 AM	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
	Prepare recorder [SONY     DVD RW DW-Q28A] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc not fixated
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    1186201600, ISRC ""
	DAO layout:
	 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
	       0 |  lead-in |   0 |    0x41 | 0x00
	       0 |        1 |   0 |    0x41 | 0x00
	       0 |        1 |   1 |    0x41 | 0x00
	  579200 | lead-out |   1 |    0x41 | 0x00
9:17:15 AM	#12 Phase 24 File dlgbrnst.cpp, Line 1832
	Caching of files started
9:17:28 AM	#13 Text 0 File Burncd.cpp, Line 4116
	Cache writing successful.
9:17:28 AM	#14 Phase 25 File dlgbrnst.cpp, Line 1832
	Caching of files completed
9:17:28 AM	#15 Phase 36 File dlgbrnst.cpp, Line 1832
	Burn process started at 6x (8,310 KB/s)
9:17:29 AM	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:17:29 AM	#17 Text 0 File DVDR.cpp, Line 2357
	Recording mode: Sequential Recording Mode for Multisession
9:17:29 AM	#18 Text 0 File Mmc.cpp, Line 21663
	Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
9:17:29 AM	#19 Text 0 File DVDR.cpp, Line 2511
	Start write address at LBA 0
	DVD high compatibility mode: Yes
9:17:29 AM	#20 Text 0 File Cdrdrv.cpp, Line 8821
	---- DVD Structure: Physical Format Information (00h) ----
	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD-R   (2), Part Version: 5
	 Disc Size: 120 mm,      Maximum Rate: 10.08 Mbps (2 h)
	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area:      0 h
	 End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
	 Data in Burst Cutting Area (BCA) does not exist
	  Start sector number of the current Border-Out: 0 h
	  Start sector number of the next Border-In:     0 h
	 Media Specific [16..63]:
	      00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
9:18:41 AM	#21 SCSI -1106 File Cdrdrv.cpp, Line 1436
	SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0B540000
	Status:     0x04 (0x01, SCSI_ERR)
	HA-Status   0x00 (0x00, OK)
	TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x73
	Sense Qual: 0x03
	CDB Data:   0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
	Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
	            0x00 0x00 0x00 0x00 0x73 0x03
9:18:41 AM	#22 CDR -1106 File Writer.cpp, Line 311
	Power calibration error
9:18:41 AM	#23 Text 0 File ThreadedTransfer.cpp, Line 228
	all writers idle, stopping conversion
9:18:41 AM	#24 Text 0 File ThreadedTransfer.cpp, Line 222
	conversion idle, stopping reader
9:18:41 AM	#25 Text 0 File DVDR.cpp, Line 2749
	EndDAO: Last written address was -1
9:18:41 AM	#26 Phase 133 File dlgbrnst.cpp, Line 1832
	Writing short lead-out
9:18:41 AM	#27 SCSI -1176 File Cdrdrv.cpp, Line 1182
	Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
	Sense Code: 0x72
	Sense Qual: 0x04
	CDB Data:   0x5B 0x01 0x02 0x00 0x00 0x03 0x00 0x00 0x00 0x00 0x00 0x00
	Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
	            0x00 0x00 0x00 0x00 0x72 0x04
9:18:41 AM	#28 CDR -1176 File WriterStatus.cpp, Line 167
	Session fixation error
9:18:41 AM	#29 TRANSFER -24 File WriterStatus.cpp, Line 167
	Could not perform end of Disc-at-once
9:18:41 AM	#30 Phase 38 File dlgbrnst.cpp, Line 1832
	Burn process failed at 6x (8,310 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 5/17/2006 1:53:54 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/18/2003 12:00:00 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
But when i try with cd's its fully working... can any one tell me the solution plz... thanks in advance.....
