HELP ME (Graphic Card Problem) Please Urgent
yarasu
I am a Graphic artist. I am not pro in Trouble Shooting. any one could help me from this problem
My config is
Intel Q6600 Quadcore Proccessor
Asus P5KC Mother Board
Gigabyte nVidia Geforce 8800GT 512MB
VIP 500W SMPS
4GB Transcend RAM (2+2)
Samsung DVD Writer
Circle Cabinet
2 LG Flatron 17" Monitors
(Every time i work on two monitors bcuz it's my job)
Problems.
1. PC temperatures are going high CPU 50Celsius and Motherboard 45C
this config is showing with the help of Asus Probe Suite
2. Every time of logon an error is show like Graphic card is not receiving sufficient power please check the cable.
But i have checked so many times and i dedicated a power line from SMPS to Graphic Card. Even problem is coming.
3 I not able to render my works and my brother cant play NFS Most wanted more than 10 min. PC is going hangs in middle of app.
Could any give suggestions
I have Seriously checked the cables. could i need more powered PSU for my work. I have taken this cofiguration with help of Digit. My PC old is 2 months only.
Is there any person to solve my problem Please urgent!
john_the_ultimate
No pain....No gain
Firstly did you connect the 6-pin pci-e connector to your gfx card ??? If no then connect it and if yes then there must be something wrong with your PSU.
Try getting a better PSU......like corsair, coolermaster, tagan etc.........if those are cpu and mobo temps are at load then they are fine. But for idle they are a little on a higher side.
Extreme Gamer
僕はガンダム!
Vendor
the psu isnt certified for geforce cards.u need at least 15A and 6pin connectors in each 12V rail.get a modular psu
spikygv
My config is
VIP 500W SMPS
Samsung DVD Writer
Circle Cabinet
Problems.
get a cooler master extreme power 600W - 3.4k
or a corsair vx450W - 3.8k
that VIP psu isnt giving enough power.
