shaunak
Tux Fan
I am looking to buy a new phone.
I have narrowed my choice to two, the k530i and the G502. I am totally confused between the two. I tried weighing pros and cons and got stuck. So I will just list them and have you guys decide.
Stuff in favour of 530i
* 3G + Dual cams (When 3G does land up here, ill be ready )
* Styling: Liked the classic candybar look + more compact
* Longer battery life + Screen more readable outdoors
*Comes With a 512MB card
Stuff in favour of the G502
* A200 interface
* QVGA screen
* HSDPA
Which one should I choose?
Also, how about the K800? How much does it retail for now?
____________________________________
If you are suggesting any other phone then:
My requirements are:
* Should be able to play my Mp3 files, decently.
* USB mass storage ready. I need to be able to transfer files under Linux (Main reason i am not buying nokia)
* Fast interface
* Dont care much for pic quality, as long as it takes pictures and is just about usable on my blog/ good enuff to email
* Dont care at all for video recording
* Dont like flashy phones
* I like SE phones , not that I am not willing to consider others.
* FM Radio, alarms and calander a must
My budget is circa 8K.
Cheers,
Shaunak
* A200 interface
* QVGA screen
* HSDPA
* Fast interface
Cheers,
Shaunak
