Help :: Ark Problem.
dissel
When ever I try to decrypt any .rar archive ...it will give me the same error as below.
There is no issue with .zip archive.
*img391.imageshack.us/img391/3536/snapshot10tc3.th.png
"This utility unrar not in your path, Please contact in your system administrator"
The whole archive in Fat32 partition and it is mounted in the following path '/media/sda7'.
So I think there is no permission/writing problem. So where is the path ? or where to insert it ?
I tried Configure Ark option but can't find any path option.
Expert/L-Gurus please help me....
For only this reason I need to start the Windows.(Power Archiver 2006)
anantkhaitan
Burning Bright
use this:
Code:
$ sudo yum install unrar
or
Code:
$ sudo apt-get install unrar
According to ur distro.
Then
Code:
$ unrar e flename.rar
dissel
dissel
@anantkhaitan
Thanks man, after installing unrar the default 'Ark' Program run fine and it will able to handle the .rar archive.
Thanks for your nice help.
