Full HD LED TV between less than 32"
DEE
Hi Guys,
I'm looking for a FULL HD 1080p LED TV which I'll primarily use for 4 things:
- Hook My Old PC (which means no HDMI.)
- Hook Set Top Box (using AV cables)
- Hook XBOX for heavy games (using HDMI.. Should have decent response time)
- USB Play (Good to have but not mandatory)
Unfortunately, I've space constraints and is running short of a few inches for 32". I wonder if there's any FullHD 1080p LED TV available just next to 32" on a lower side in size. I searched a lot - Sony/Samsung/AOC/LG... But couldn't find any FullHD between 24" and 32". There are few 26" and 28", but all are max 720p.
I'd highly appreciate if you can suggest any LEDTV or monitor that suffice my needs. If there's nothing between 24 and 32. Please suggest a 24" considering my needs :(
Thanks
Minion
Re: Full HD LED TV between less than 32"
Get Samsung 26EH4800.
It has very good sound So you will not need any Sound bar. This model too is not a full HD but this is the best you can get within your budget.
D
DEE
Thanks Minion. However, in your opinion is FullHD Monitor+ SoundBar+Media Player a better choice over 720p TV? I can extend budget max upto 30k.
Empirial
This is a good option for you & don't worry Toshiba is a reputed brand ..:: Toshiba thinkingLED ::..
D
DEE
Thanks Empirial.. Looks promising. Only concern is that its 720p. But does it really matters as I'm excluding so many options just because they are 720 p in not 1080p. :(
Empirial
Buddy, I once read in AV Max magazine that FHD makes sense only on 42" and above screens. It is almost impossible to spot any difference between FHD & HD in smaller displays. Also, you said that you don't have enough space for 32" so I'd suggest you to consider Toshiba 29" Led Tv :)
Minion
If you are increasing your budget then get Samsung 32EH5000.Its a full HD T.V. A full HD monitor can't match PQ of a tv due to use of inferior panel.
D
DEE
Not purchased yet (will soon and share)... However I'm inclined towards TV than monitor because I believe xBox will play better on TV and also with TV available instead of monitor, others can enjoy it too and I can save speaker space.
ashusood331
Hi there, I am not too familiar about the TV technology but I can suggest you according to your budget which you can conveniently choose among several brands models which cover HDMI, USB port, support gaming, 1080p & definitely in size which can get fix comfortably at your place. How about buying with some interesting money saving this season. I am sure you will not miss picking your favorite brand LED TV from Snapdeal. All the best for your pick.
D
DEE
32" won't fit while there isn't FullHD in lower sizes.. So finally ..a 27" Full HD monitor. Any thoughts from actual users on attached finalized monitor chart (chek monitor.png).... I'll go with one of these...
GREAT if actual users can share there console(PSP/XBOX) attachment and movies experience with any of these to help me buy..
Thanks a lot in advance :D
D
DEE
I'll buy either of BENQ EW2740L OR AOC i2757fh..... FINAL!!
Any thoughts from users owning either of the 2.....
Just want to know how games and movies look on these two.
Thanks
