Front panel audio connection onboard help needed?
bhush_18
I am having a Mobo os MSI with front panel audio connection as per Intel I/O.
AC'97 6.1ch onboard.
There are 10 pins on it as follows:
pin 1 AUD MIC
pin 2 AUD GND
pin 3 AUD MIC BIAS
pin 4 AUD VCC
pin 5 AUD FPOUT R
pin 6 AUD SPK R
pin 7 HP ON
No Pin key
pin 9 AUD FPOUT L
pin 10 AUD SPK L
Now on my cabinet there is connection for a Mic & 2 speakers (3 wires each).
How do I connect these & what are the other pins meant for?
klinux
try checking the manual or intels website . I think ur board works with multiple speaker output , while ur cabinet works only for 2 speakers , ie two channel output . under normal situations , front panel audio is mainly used only for head phones , so that u dont have to go back all they way to fix a headphone , that to with a short wire . the three wires must be for Left , Right and Ground . Just try fixing ,
pin 6 AUD SPK R
pin 10 AUD SPK L
alone and check if u get sound . check if u have similar markings on the cabinet wires too .
B
bhush_18
I had connected pin 2 AUD GND for all 3 ports i.e. 2 speakers & one MIC Ground (common) connection. And remaining as follows:
pin 1 AUD MIC
pin 3 AUD MIC BIAS
to MIC port.
pin 5 AUD FPOUT R
pin 9 AUD FPOUT L
to SPeaker 1 port.
pin 6 AUD SPK R
pin 10 AUD SPK L
to Speaker 2 port.
out of these only speaker 1 port (i.e. FPOUT R & L) is working.
I need to check for MIC.
