i Cant log in MSN 7.5 error code 80048820 and neither is my gmail notifier or google talk is connecting , this is while i am using my broadband connection ( ps : from local cable walla ) how ever if i connect frm my dailup .. it works fine.. i already cleared my HOSTS file and tried the following suggestion.. still unable to login. I am not sure.. but i think it happened after i installed yahoo toolbar to mozzila firefox. Now that i have un installed it still that stuation remainds.
OS : Windows XP SP2 , with all patches and updates
Firewall : Kerio
MSN : 7.5
Google talk : Latest
Dialup : Airtel Live
Other Symptons
1) Even gmail was not opening in IE or Firefox.. but now its working file.
2) There could be a problem with DNS ( this i am assuming but not sure )
3) I have disabled firewall and tried no Luck ( remember works fine on dialup)
4) Please HELP !!
Update : ( Sept 23 , 2005 ) 22:00 Hrs.
I installed GAIM 1.50 , it stops when it says "starting authenticating" of msn
account and doesnt go any further says , cannot authenticate ,
cannot connect . But trying same from dialup whole process completes
without any glich.
Firewall : Kerio
MSN : 7.5
Other Symptons
4) Please HELP !!
without any glich.
Since you can't immediately login, remember that you can try logging into the Web Messenger,
at least until you can restore your normal Messenger functionality:
*webmessenger.msn.com
However, here are some suggestions you should check/try if you haven't already.
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password @ *login.passport.com/ChangePW.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
and do the same for the following:
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 MSXML3.dll
