DATA CABLE is not detected by Oxygen. Please Help........???
zeeshan_04
I brought a USB DATA CABLE for Nokia 1100 from Piyush. ( IND Cables )
I installed the drivers and everything and conncted the Cable 2 my mobile.
But Oxygen Phone Manager is not detecting the phone.
The Cable is installed at COM 4 port.
In Oxygen , when I go to Tools>>Options>>Connection & Common category, i added COM 4 but still the phone is not detected.
Please help. Thanks
IG
*indcables.crmdesk.net/
there is a link to the ind cables forum where something like ur problem is discussed.hope this helps
theraven
check if it works with the nokia pc suite .. if not .... ur cable is faulty !
also check if it IS com4 !!
ishaan
try using the mobisoft software also...look on google...my cable didnt work with oxygen (for a nokia 7250), but worked for this software. after using this software, it worked for oxygen also.
