cpu speed problem
jacques
Hi all
I m using P3 ,OS win98se, when i start the computer every time i get a msg that select Your CPU speed and press a key to boot. After pressing a key BIOS automatically get open. I m worried that have some problem in my computer. Plz buddy help me out.................
Chirag
Same prob occured with my frnd. I told him to replace the CMOS battry with a new one. And after he replaced the prob was solved. So try changing the CMOS Battry.
mohit
The Hardware Labs
ya it seems like your bios settings are getting reset due to a drained out battery.. do replace the battery and confirm.
