Conversion to audio
Hey, can someone tell me that how can I separate audio from an MPEG-1 video or any other video format. (Preferably, MPEG-1)
Gigacore
Dreamweaver
use Xilisoft 3gp video converter, and add the video file and in export file format select .mp3 and start the process. . . .
Note: the trial version will convert only 50% of the original file.
You can export the entire audio of the video file. . . i.e you cant mention from-to lenght . . . you can use other audio editing app to crop
anand1
Ya you can do that with the Software mentioned in this link. These all softwares are Freewares.
*www.freewarefiles.com/program_6_226_35165.html
