suyash24seven
I own a Samsung Galaxy Note 2, and while it's charger is working fine, the cable developed some issue due to which the charging became painfully slow (took 4-5 hours to charge). I also own a Sony Xperia phone and a Kindle Paperwhite, both of which charge through a USB-microUSB cable.
So I started using the cables of the other two devices with my Note 2 charger, and the charging was fine and speedy. That is, I always used only the original Samsung Galaxy Note 2 charger, but I used Kindle or Sony USB cable with it instead of the Samsung cable.
But now it seems my battery has developed some serious issues! It discharged from 100% to 0% in 6 hours!!
I was under the impression that using a different cable won't cause any harm.
Was I wrong? Or may be there is some other reason for the battery drain?
Please help. Thanks a lot.
