Buying Advice Reqd : 40" LED SMART TV
Soumyajit
Novice
Hi all,
Require buying advice for TV. Details required as per questionnaire are as follows :-
1. Budget? <50k
2. Display type and size? 40" SMART LED (Android OS preferable)
3. Primary use of Tv/monitor? TV viewing at home. Tatasky, Youtube, Netflix, Movie streaming from laptop,etc.
4. Ports Required? HDMI, USB, WiFi
5. Preferred choice of brand? Nothing in particular
6. Any TV/monitor in consideration? No
1. Budget is a consideration.
2. Which would be cheaper option? Showroom/multi brand dealer (location : Delhi) or e-commerce portals
Thanks & Regards
Minion
Get this
LED TV 43PUT7791/V7 | Philip
You can get this for 39k from here Philips 109.3 cm (43 inches) 43PUT7791 4K UHD LED Smart TV (Black) Price: Buy Philips 109.3 cm (43 inches) 43PUT7791 4K UHD LED Smart TV (Black) Online in India -Amazon.i
