Broadband and Wireless router help
ramprasad
I have Tikona broadband via ethernet cable.
I have plugged it into Dlink Wireless Modem Router - DSL 2730U
I have enabled DHCP and set the DNS manually in the router.
I connect my smartphone (Samsung Galaxy Y) to the internet using WiFi thrrough the same router. There is no problem in this.
However, I also use a laptop with Windows 7 installed to the router.
I am able to connect to the Modem router and not to the internet.
I get a 'time out' page.
Can anyone help me to solve this issue.?
ramprasad
ramprasad
Hi Madhu,
My DNS settings on the router are
Primary : 113.193.1.14
Secondary : 113.193.0.148
On my laptop, the adapter is set to get the IP address, gateway and DNS automatically.
Do you need me to post any specific settings.
I tried the url u had given me and also 1.254.254.254
It always returns the 'time out' page.
But through my phone, displays the 'Tikona login' page
I am sure that I am missing something :(
khmadhu
change is constant!!
what's u r laptop connection shows.. ? connected /limited connectivity..?
r u able to ping u r Modem Router - DSL 2730U. (192.168.1.1/2.1) ?
also check any firewall u have enabled..
ramprasad
ramprasad
The wireless connections shows as 'Limited connectivity'.
I am able to ping my modem/router without any problem.
I can also open the administrative portal of the modem/router.
I am able to connect to the tikona login page if I connect the ethernet directly to the laptop.
One puzzling thing is that very rarely (may be once/twice) in a day, I am able to get the login page in my laptop when connected through the WiFi Modem/Router.
Not sure how to handle.
khmadhu
I have a doubt that u r laptop to router is a problem.
the connection is wired or wireless.?
in case of wireless, make sure u r laptop is within router;s wifi range.(atleast 3-4 sticks in network status).
in case of wired make sure u use straight Ethernet cable and not cross-over.
whats the IP u get to u r laptop..?
i too use tikona with belkin router. i use to get same problem with my desktop wifi module!. then realized that its a wifi range problem..
jags_mcp
I would like to know the configuration you have set for your Router. I am on the same line but for me it is not connecting from anywhere.
khmadhu
@ ramprasad
change the Router's manual DNS to Auto .
nowadays tikona is not working if u r Router DNS is changed other than ISP. before it used to work with opendns!.
