Hi
I have a laptop which I use to carry work between office and home... Since I mostly use it at home and office and not while carrying it around, most often I am able to use a power supply to avoid battery getting drained...
However, recently a computer technician told me that if I dont use the battery at all and use power supply to work on the laptop all the time, the battery will drain and start losing its capacity... Is this true? If so, when I use battery, is there a particular level to which I should allow it to drain before connecting it to the power supply (to maximise battery life)?
Thanks in advance
Arun
Thanks in advance
Arun
