8 gallons of cooking oil in ur cabinet
ashfame
Source : *www.tomshardware.com/site/videos/index.html
"What happens when you seal tight a PC case, strip out the fans and add eight gallons of cooking oil? You get a totally silent and cool PC. If you don't believe me, check out the video of a working AMD Athlon FX-55 and GeForce 6800 Ultra system submerged in an oil-filled case--or should i say tank."
Download the divx video of this working system here: (20.3MB)
*www12.tomshardware.com/images/thg_video_18_oil_cooled_pc_divx.zip
saurabh.sauron
i dont know....but how will u stuff 8 GALLONS of cooking oil in a PC. i doubt that it will hold more than 5L. and btw, if we tried, we'll be bankrupt. 1l-60Rs.
:D :D :D
khansdream
Nice stuff............!!!!
Will suggest others and see the result..............!!!!!!!!!!:D ( Never saw a Deep-Fried PC)
QwertyManiac
Commander in Chief
:D :D :D
Lol there are various sizes of cases available :p
Well, what if I want to cook?
Vyasram
The pWnster
LATEST FRyING PAN (PATENT NO 1248702356324905204862-913 BY VYASRAM)
Rest the pc cabinet on its side, fill with oil after sealing the sides,use an intel ee cpu overclocked to triple its value and use four ram sticks. remove all fans and coolers. Now u can make puri's and vadas
ashfame
ashfame
Guys download this video.
It shows 3dmark05 running while they are adding oil in the case.
COOOOOOOOOOOOOOLLL!!!!!!
Ashis said:
Won't it led to short-circuit?
Don't know, it must have short-circuited?
Vyasram
The pWnster
how can we be so sure dat they used that oiled system, thay cud have connected another one to the monitor
ashfame
ashfame
@ vyasram
if u download it u can see the lights inside the case which means its powered on!!
If its powered on & running then whts the use of connecting screen from a diff. PC.
dIgItaL_BrAt
ROTFL
Vyasram
The pWnster
@ashfame
They mite hav used waterproof leds connected to a power source exclusively with the power off. Anyway, only one way to find out whether itz true, do it ourselves!!!!
ashfame
ashfame
Vyasram said:
@ashfame
Only one way to find out whether itz true, do it ourselves!!!!
i can't try it coz if i & something goes wrong then i am doomed but u can give it a try buddy!
Ur expense :
1. Some silicon paste for making case water proof
2. Cooking Oil
LOL....
