42+ inch led TV advice
Fahim Hafeez Bepari
Hello friends
Pls help me buy 42+ inch led TV..
1. Budget= 50k
2. Display type and size= led 42+
3. Primary use of Tv/monitor=tv
4. Ports Required=min 2 HDMI and 2 usb. Ethernet preferred(not compulsory)
5. Preferred choice of brand=LG
6. Any TV/monitor in consideration=LG LF436300
already own a lg cs560 2013 model in my native. Very much happy and satisfied with the quality and knock IPS panel.
I require a new TV in Bangalore. Room size is 16feetx20feet.
TV to be used mainly for watching movies. Sound quality need not be a criteria as I m going to attach 5.1 speakers additionally.
Thanks for ur advice in advance.
fahimbepari
Problem with Paytm is that the Cash back is in the form of PAYTM wallet.
Neways guys how is "Mitashi MiDE050v01 FS 50 Inch LED TV (Full HD)" saw it in store found the quality much better than micromax and VU..
v.Na5h
Off Hook!
Find or the panel and firmware they use
If it's hisense then it's same as micromax and vu
