40 to 43" FHD LED TV required within 50-55K
surya_sapui
Dear guys ,
I need a 40 to 43" FHD LED TV required within 50-55K.
i searched for palsma TV but its not akindly suggest
1. Budget?
Upto 55K
2. Display type and size?
40" to 43" LED FULL HD
3. Primary use of Tv/monitor?
FHD movies & Games.
4. Ports Required?
2 or more HDMIs and USB (is there anything else? )
5. Preferred choice of brand?
Sony, LG, Panasonic
Not Yet
smart features & 3D if available.
IMO, a 1440p monitor would be much better if you plan to game more than you watch movies.
Also, which GPU would you be using?
ssb1551
Wow!! I can see how disinterested you are in typing lol :D. Is it the GTX 1060 3GB or the 6GB variant? If it is latter then whether is it the Mini or AMP edition? Guess those 2 questions will tell us which exact GPU you have.
^could you tell me what features to look for if buying TV for Games + Movies?
Low response time, preferably 5ms or less, good coverage of colour spectrum, good viewing angles and at least 1080p resolution.
On the connectivity side, at least a HDMI, DVI-D or DisplayPort.
Minion
You should first consider if your GPU can support that resolution suppose you have a old graphics card and you bought a 4k TV and that would be total disaster.
Then look for panel type IPS better viewing angle but lower contrast ratio while VA has better contrast ratio but not so great viewing angle then you should consider panel refresh rate panel with low refresh rate it will show you blurry image with fast action then you should look for tv with atleast 3 HDMI ports.
