XP SP2 Setup Problem-need quick help!
mannuforall
mannuforall
My system: Intel 2.66ghz, 256ram, 845 mb, 80gb sata,
I've XP SP2 installed in, but after a virus attack, I delete virus files detected by avast 4.8. But when restart my system it unable to boot. So I decided to reinstall XP. I delete old XP and format c: then install fresh XP.
NOW problem is that when it reached on 'Installing Device Drivers' or near, system stop responding and stop at this point. I try with another cd but it same.
Plz help...
dhanusaud
optical drive problem!!!!
change your optical device & insert XPCD, restart install, it should work fine. if you are sure that you don't any virus in your system left behind then try repairing instead installing.
mannuforall
mannuforall
mannuforall
Thanks to all you. After using a new optical drive the installation is now complete successfully. Thank a lot specially dhanusaud.
