Hello, I need a new TV for my room..
But I m confused on whether to buy 32 inch monitor or a 32 inch TV ??
I will be watching sd content .. and also gaming on it sometimes..
Pls suggest which will be better ??
If you are going to game on it (AKA if you have a PS4 pro/One X, or a decent gaming PC with 1060+ GPU, then monitor is recommended)
Otherwise get a TV (1080p)
