URGENT!!!NEED ADVICE FOR CABINET AND CPU COOLER
himanshu_game
Creating New Worlds
my proccy q6600 temp heating a lot with temp. exceeding 77 C under average usage.
and under crysis it reaches 87-88 C .due to which my whole system temp getting higher.Around 50 C for mainboard.61 C for hdd.My current cabby is a intex cabinet which i purchased for .5k ...
NOW i need a new cabby..
PLEASE SUGGEST A GOOD CABBY ASaP...
and do i Need a CPU cooler..>
if yes suggest that also....
MY whole system is MEltING:shock::sad:
desiibond
Bond, Desi Bond!
Himanshu, there is one cabinet in zebronics with 220mm huge side fan. Check for this and add few more fans to this cabinet and you are good to go. :)
himanshu_game
himanshu_game
Creating New Worlds
which model no and for how much??
are thes zebronics cabby's r as gud as coolermaster's 690 etc ?
and wat abt build quality?
screwless design?
Now i changed d place of my cabby temp. reduced to--
CPU- 55-60 C idle
GPU--42-52 C idle
do i need a cpu cooler
my Mobo is Abit -ip35P
desiibond
Bond, Desi Bond!
They are decent. You can't compare it with CM 690. It costs less than 2k I think. BTW, CM 690 will become a worthy buy if you put
1 fan at top and one at the bottom and 1 one left side. Then you will find total reduction in temperatures.
himanshu_game
himanshu_game
Creating New Worlds
how much marks u will give to--
------------------------------------CM 690------- ---ZEBRONICS
1)BUILD QUALITY
2)COOLING
3)PRICE
4)DESIGN
5)CONCLUSION
and do i need a cPU cooLER?
desiibond
Bond, Desi Bond!
1)BUILD QUALITY
2)COOLING
3)PRICE
4)DESIGN
5)CONCLUSION
1)BUILD QUALITY: 8
2)COOLING: 10 (8 coolers can be installed. awesome. freaking awesome)
3)PRICE: 6
4)DESIGN: 8
5)CONCLUSION: 8
Krow
Crowman
Its the Zebronics Rage. I say go for CM. If budget permits, then go for CM-690(with the transparent side panel)! Else u cn have a look @ The CM Elite 334 @ 1.8-2.2k. For the CPU cooler(if u happen to decide that u wanna buy it), u cn have a look @ the OCZ Vendetta 2 for Rs.2.5k. Another good cooler is the Arctic Freezer 7 Pro for arnd 1.6k(not sure, plz verify).
Whichever CM cabby u buy, if u install fans(80/120mm) @ the right places, the overall airflow will be excellent.
