akash_bhavsar
I have a P4 3.0 Ghz PC with an Intel original 865G motherboard, 80 GB HDD, 512 MBs of RAM and an Iomega DVD writer. I have only Windows XP Pro + SP2 installed on the C drive of the disk. Since about 2 weeks, i'm facing an unusual problem...
At times when i start my PC, no matter what shortcut or program i click on, only one warning gets displayed - "Windows cannot access the specified device, path or file. You may not have appropriate permissions to access them."
I get this message even when i click on 'Help' or 'Run'... I checked and verified if i am logged on as the Administrator. But still it shows the same message. All i can access is Explorer. I can just browse through my drives and documents...
The only solution out is scheduling a Scandisk check of C drive on the next system startup. The PC boots as ok the next time. But after a couple of restarts, the same problem arises again!
It is getting really frustrating... Please help!
