rohit32407
First of all here are my system's specifications-:
i5 2500K (running at stock speed right now)
ASUS p8z77-m
Gskill ripjawsx 1600 Mhz DDR3 (4Gb x 2 = 8 GB)
Seasonic s12II 620w
running on onboard GPU
2 Seagate HDDs
Sony DVD writer
now since i had to ship my gtx 560 to a buyer so i disconnected it. Did a bit of cleaning inside the cabinet with blower(please note that I did not disconnect any component except the RAM while cleaning). Connected RAM and everything and connected monitor to the onboard GPU. At first it did not boot and restarted 2-3 times by itself so i opened my cabinet again and restarted it again and saw that DRAM_LED was lit continously. I took out ASUS's manual and it said that continuously lit DRAM_LED meant that either the ram was not in its slot properly or it was not compatible with the motherboard. Since i have been using this same RAM modules for last 3-4 months on this very same motherboard so I knew it was not compatibility issue but in any case I pressed the memok button. It still did not boot so i reseated one RAM module at a time. With 1 RAM module it booted so I inserted the second module and it booted without any problem with both modules at their proper slot. Because of all this restarting so many times or for whatever reason windows 7 got corrupted and wont start. I tried to run its recovery software but it could not solve the problem. then i thought there was no other way but to reinstall windows but to my amazement it won't boot through DVD drive at all. Just yesterday my DVD drive was fine. I restarted and went into bios to see if it was detecting every hardware or not. Everything looks ok on bios. As the last resort i updated bios though i doubted it would solve anything. Well it didn't. Now as soon as windows startup screen of windows come there is BSOD and it just restarts.
In nutshell my problem is this-
1) Bios is detecting every hardware correctly and everything seems to be working fine.
2) Booting with DVD drive is just not working. I doubt that DVD drive might be the culprit but i wanted to be sure if i could have messed up something. I doubt it coz bios shows everything to be under control. I did not touch any component except for the RAM while cleaning. I have tried connecting DVD drive to different SATA port but it still won't work. Can there be any other problem or is it just the faulty DVD writer which miraculously went kaput overnight. I would like to mention that BIOS is still detecting the DVD drive with its proper ID.
3) I would also like to mention that whenever there is a DVD inside the drive even entering into BIOS takes about 20 seconds. As soon as i take out the DVD from the drive it instantly enters the BIOS.
I know it's a lenghty post but i wanted to explain my every action properly. Please advise what needs to be done.
ASUS p8z77-m
Seasonic s12II 620w
2 Seagate HDDs
Sony DVD writer
