surya_sapui
Hi Guys,
I want to buy 50 to 55 inch best Led within 1 lac.kindly suggest the model name.My location is kolkata.
I want to buy plasma because for low budget plasma is best but now a days plasma not available.
1. Budget:Within 1 Lac
2. Display type and size : 55"
3. What will the TV/monitor be used for primarily : HD Movie
4. Types and number of ports required : Does not Matter
5. Preferred choice of brand : Sony, Panasonic,LG, Samsung
6. Any TV/monitor in consideration : No
7. Any other info that you want to share : Within 1 lac can i get a good Television or need to increase the budget.because i dont want to compromise the Quality.
Kindly suggest which model on this budget best for me also good durability.
