Samsung 660 Data Cable Problem
Discussion in 'Buying Advice' started by *AritrA*, May 30, 2006.
Thread Status:
  1. *AritrA*
    *AritrA* New Member
    May 19, 2006
    10
    0
    0
    Few hrs back i hve bought a data cable for my samsung X-660.installed d driver.it shows on port 3 in device manager.but whn i open d given software , Easystudio PIMS and file manager ; my mobile is nt detected .
    my frnd has d same set n also bought the the data cable frm the same shop .bt he is far away n i need help installing .
    HELP PLS !
  2. hsksattish
    hsksattish New Member
    May 29, 2005
    58
    0
    0
    Tamil Nadu
    hey i too got a similar problem at first. Did u install all the easy gprs and image editor softwares??? my problem got rectified when i did that
  3. OP
    *AritrA*
    *AritrA* New Member
    May 19, 2006
    10
    0
    0
    no .. i jst installed PIMS Easy studiop and file manager .. will b installing the rest nw that u said . hpe everything gets working !
  4. montsa007
    montsa007 ~Bulletproof Monk~
    Nov 9, 2004
    1,180
    5
    0
    Mumbai
    dude check ur computers properties check the exact com port coz this happenned wid my nec e606 check the com port in coms hardware profiles and put the same in ur mobile software
  5. OP
    *AritrA*
    *AritrA* New Member
    May 19, 2006
    10
    0
    0
    i hve done all sorts of things that cud hve been done .. Evrything.. will go to change it tomorow.bcoz i hve jst chked with another frnd of minw who has d same molile n data cable .. my data cable is nt working in his pc also n his data cable works perfectly with my pc n mobile .
    n i hve the receipt ..so hpe they will change it .
Thread Status:
Share This Page
