Redmi Note 10 Pro or Pro Max ?
vishk
Hi Guys,
I am confused between buying Redmi Note 10 or the Pro Max? Which one should I go for ? Looks like other than the Camera Bump there is no Major difference between the two ? I plan to keep this Phone for atleast 2 years. So which one should I go for between the two ? What is the key difference between the two ?
TIA !
ankushv
As the only difference is camera I guess , the pro variation may suffice . But for a mere 2 k I'd go for the pro max variant . Even though I'm quite sure the larger mp camera will not justify the extra 2k .
Cheers !
Ankush .
Sent from my SM-G960F using Tapatalk
