Rechargeable Battery (AA & AAA) and Unit
bad_till_bones
Ðèåd Måñ Wå£KîÑG
Need a rechargeable unit and battery (both AA and AAA).
Hope there are units which can charge both type of batteries.
Please suggest.
Ascendant001
I don't think we can use Duracell rechargeable on Panasonic Eneloop. Can we?
Ask the seller for confirmation but as far as I know any Ni-MH rechargeable cell should be chargeable by any Ni-MH cell charger as it is just a simple battery with no proprietary connectors/charging tech. See the pic in the review below, guy is using different brand cell in panasonic charger.
*www.amazon.in/gp/customer-reviews/R2L80QQGSPI6YM/ref=cm_cr_dp_d_rvw_ttl?ie=UTF8&ASIN=B010I0STUY
bad_till_bones
bad_till_bones
Ðèåd Måñ Wå£KîÑG
Right bud.
Please link me to the AAA and AA rechargeable batteries that I can buy.
I have ordered the Eneloop smart charger.
Ascendant001
*www.amazon.in/Panasonic-Battery-En...00JHKSL28/ref=cm_cr_arp_d_product_top?ie=UTF8
Check review:
*www.amazon.in/gp/customer-reviews/R1E9ZUN0RZLJ0A/ref=cm_cr_getr_d_rvw_ttl?ie=UTF8&ASIN=B00JHKSL28
*www.amazon.in/Panasonic-Battery-BK...eable+aaa&qid=1596164664&s=electronics&sr=1-4
Check reviews for above as stock is likely 2018 manufactured.
*www.amazon.in/Duracell-AAA-750mAh-...96164664&s=electronics&sr=1-3#customerReviews
Check the first top review & also latest reviews.
bad_till_bones
bad_till_bones
Ðèåd Måñ Wå£KîÑG
I purchased BQ-CC55E smart charger with auto cutoff.
Also purchasedd 4 AA (2500MAH) and 4 AA (900MAH) Duracell rechargeable batteries.
While charging AA batteries the light indicator acted OK. Like it turned off when it completely charged the batteries.
However, the light is stuck at GREEN while charging the AAA batteries. It's been more than 3 hours they are GREEN.
Light indications are -
0 to 20 - RED
20 to 80 - YELLOW
80 or more - GREEN
100% Charge - Light off.
Ascendant001
No need to charge cell right till 100% in that case, calculate the full charging time & then take off the cells at ~85-90% mark.
