A
amit.tiger12
Guest
I have nexus 5 mobile and charger is giving 1.2 Ampere output. But I think charging is not that fast. I want better charger with almost 2.1 Ampere and above output, so that I can charge my mobile (Nexus 5= 2300 mAh battery) much faster, may be in 45 min or less than this. I want only wall charger, car chargers gives more output like 2.4, 3.5, 4.2 or 5 etc etc. But I dont have car .
So wall charger I needed at least 2-2.1 ampere output. Just for information Oppo Find 7a has 2800 mAh battery life, comes with 4.2 Ampere charger and charging time is around 82 minutes for 2800 mAh battery.
So need help buying chargers.
I searched and found these 2 chargers.
ERD Mobile charger USB LP-27TC - 2 Amp output = rs 250
Sony CP-AD2 USB 2.1 amp = rs 520
ERD is good charger I used this charger (0.7 Ampere) for 2 years. And still its working but output is not that much as of nexus 5 charger 1.2 ampere.
There is no budget for charger, but if can suggest below 500 rs that will be good. And you can suggest above 500 rs also one friend needed some branded charger. Charger for me and my friend. Will find in local stores also, but friends need your help for specific model you know for fast charge, if you are using it now with no issues.
