My PSU fan had started making lot of noise. It is a sleeve based bearing Fan. I tried using sewing machine oil to silence it, it was running without noise for a couple of months and the noise started once again.
My current PSU is : Cooler Master Extreme Power 600W Power Supply
1) Can you please suggest whether I can replace the fan alone, if yes, can I buy any 120mm Fan or what spec should I check ?
The existing fan in the PSU is:
Model Part Number: AD1212US-A71GL, 12 Volts, Current 0.5A
Service Unavailable
2) If I have to replace whole PSU, can you suggest some good PSU for my current PC config below. Budget: Rs.3000 to 5000 (should be able to support any future upgrades )
My PC Config:
Processor: Intel E8400
Mother Board:Abit IP35E
RAM: Corsair 2*1GB(800MHz) - TWIN2X2048-6400
Graphics Card: Sapphire HD5670 1GDDR5 PCI - E HDMI/DVI-I/DP
HDD: Western Digital Caviar SE16 320GB 7200RPM 16MB (WD3200AAKS
Cabinet: Cooler Master Elite 330 Computer Case
DVD Writer: Samsung SH -S203 SATA DVD RW or Lite - On 20X With Light Scribe
UPS: APC 650VA
Service Unavailable
My PC Config:
UPS: APC 650VA
