My Laptop info
Core i7 2630QM @ 2.0Ghz
Radeon HD 6770 M 1 GB DDR5
Intel HD GPU
DDR3 4 GB 1333Hz Ram
I have this problem often. While playing certain games ( NFS Rivals, Grid 2 - even in low graphics) most often I get it hanged in after few min, and get a message that GPU had restarted. Is it so that the GPU is able to control these high end games ?. But I have no problem Playing Maxpane 3, NFS HP 2011, NFS RUN etc.
I have my Switchable GPU option to use High Performance GPU ( Made it Static in the BOIS). Does this means HD 6770 M GPU is alone used and not the Intel GPU? If so is there any way to make the game to use both the GPUs.
Intel HD GPU
