Problem with my Nokia N73 ME.... Please Help!
mrintech
Hey Friends, Need some help
Though I got some solution via CHAT. But still I want to ask here. I am facing some problems with my New Nokia N 73 ME.
Note that I haven't installed any additional software in it. All the applications are completelt default. The main reason for this is that My Priorities of Phone Usage is very very specific and I request you all to please help me with the following points only. I am not interested in tweaking/squeezing N 73 Power to MAX or whatever.
1. I downloaded some .3gp format videos from www.zedge.net and also got some videos in .3gp format from my friend's Mobile (via Bluetooth). The problem is that the Sound is very very low in Real Player even in full volume, though the video is completely working fine with no problem at all. Please suggest solution/software for this.
2. Some new .mp3 songs (which i got from CDs) fails to play in default music player of N 73. There is a Red Cross (X) sign before the name of the songs which can't be played by the player.
Whenever I try tto play them, the player automatically skips to next available playable songs. I repeat this problem is with new .mp3 songs only, old songs are working completely fine. Please suggest solution/software for this.
3. When I make a Call, the Phone is not showing up Call Duration (hh:mm:ss) during the due course of the call. It's only showing up when I disconnect the call. Any software for this?
4. I want to know softwares for following categories (if available):
* Which automaticcaly Locks the Key Pad after a certain period of time.
* Which makes Bluetooth OFF after certain period of time, if kept ON.
5. This is the question which is bugging me a lot. Some people says Hack your N 73 Mobile? Now what is this?
If yoyu can suggest softwares/suggestions for above points without the need of hacking Mobile, than it will be really very very cool.
Help Appreciated
- With Best Wishes :)
utsav
damn busy...
For call duration . go to Log > Settings> show call duration.
Now u will be able to see the call duration while on call
The reason for low volume of 3gp vdos is most probably the low volume of the video itself. Install coreplayer on your phone and then play those videos and they might play a bit louder.
For MP3s showing cross prblm. Remove those all mp3s u added and again add some new mp3s .rescan the library and try playing them.
krates
Be CoOl rAp RuLeZ !!!
Video problem buddy....
i think you are having that funny problem which i used to have you better update your firmware to the latest one...
[/quote]
no idea ..
*use autolock...
*no idea
glup glup.... will tell u on messenger ..
