problem in starting and speed
Hi
en error message is coming "NT On-Access Scanner service. has encountered a problem and needs to close. We are sorry for the inconvenience." What may be the problem?
vishal
prathap_lab
hi
hi,
i think this may be the reason.
if you have both NAV and mcafee installed on your system, tihs error may occur. if this is the case then uninstall both of them and reinstall only one. i prefer nav.
thank you.
A
anurag_online
Guest
Hmmmm
Although less information... but my thought is going for the problem occuring because of some software may be a game..... so try to remove the last updates and if the restore service is present restore ur pc to an older date. May solve your problem...
enoonmai
NT On-Access Scanner Service is the mcshield.exe file, part of McAfee VirusScan. A simple reinstall of McAfee VirusScan from the original installation disc should fix the problem.
