Power PC build
dheerajpant
Hi Guys,
I want to build a home lab that will also function as a NAS server.
I have a PC and was thinking if I can use some of its components, this will reduce the amount of money that I will have to spend.
I had build that PC for gaming, but now a days I don't play much(just keep on buying games :(), if I am not able to use any of the components will try to sell it as I might build a separate PC for gaming purposes :).
The PC has the following components:
Cooler Master RC-130 Mini ITX
Intel Core i5 4460 Quad Core LGA 1150 3.2GHz
Gigabyte H97N-WIFI H97,LGA1150,2DDR3-1600,RAID,PCIE3.0,SATA6Gb,Atheros 8161B GbE,USB3.0,2XHDMI,DVI-D
Kingston HX316C10FBK2/16 16GB Kit HyperX Fury Black 1600Mhz
Gigabyte GeForce GTX 970 G1 Gaming 4GB
Kingston 250GB SSD
Seagate 750GB 7200 RPM HDD
Ans: Planning to use the system as a homelab and NAS, that will run atleast 4-5 VMs concurrently(might increase to 8 in some cases). Not planning to use it for gaming as this system will be running 24x7, GPU will\might make it more expensive, happy to be corrected :).
Ans: 1,50,000 - 2,00,000 (would like as cheap as possible :)) ... I was thinking if required I can compromise on certain components right now and upgrade in future, example I was planning for 64GB RAM, but can go for 32 GB right now and buy a 32GB in future.
3. Planning to overclock?
Ans: No
Ans: Mostly Linux
Ans: 1 TB SSD for OS and Cache.... and around 4(or 6)x4TB HDD 7200 RPM (NAS) ....
Ans: No
Ans: If I can reuse any component from my existing PC that will be great, don't require keyboard, mouse.
Ans: I am in no hurry, and can wait if there is a possibility that some of the components might get cheaper.
Ans: Yes
Ans: Online\Store which ever is cheaper.
Ans: Ideas on should I build 2 separate system(homelab and gaming) or a single system? And as the system will be running for long hours(possibly 24x7), if possible I would appreciate components that use less energy.
Thank you.
Budget -184k (AMD HomeLab/NAS RIG)
AMD Ryzen 9 3900XT -42.5k
Asus TUF GAMING X570-Plus (Wifi) -19.9k
G.Skill TridentZ NEO RGB 32GB (16GBx2) 3600Mhz -19.8k
Antec NEPTUNE 240 ARGB CPU Cooler -7.2k
Kingston A2000 1TB NVME SSD -9.9k
Seagate Barracuda 4TB x4HDD's -8.2 x4 =32.8k
Asus Cerberus GTX 1050 Ti 4GB -13.5k
Lian-Li Lancool 215 Cabinet -6k
CoolerMaster MWE 850W Gold Modular -9.8k
Acer NITRO VG0 VG270 27 Inch LED IPS -17.8k
CoolerMaster MS110 Combo -4.8k
Total -184k
All above prices are taken from vedantcomputers unless specified otherwise.
According to the PSU Calculator *i.imgur.com/T8xeXqy.png
D
dheerajpant
Thank you Sunil,
So the recommendation is to go with a single build that will work as a work horse as well as a gaming rig?
And will the recommended cabinet be able to hold 4x3.5"?
Thanks
IMO use your old PC for just NAS, not much idea about how to set it up, but heard it doesn't require a high end system.
Build a new PC for gaming + workstation usage. As your old i5 has an iGPU, use your GTX 970 as dGPU in the new PC as currently GPU prices are very bad & might take 6 months to stabilize or worse.
CPU - AMD R9 3900X/XT - 42k
CPU cooler - Deepcool Gamerstorm Assassin III - 7.5k *
Mobo - MSI B550 Gaming Plus - 14.5k
RAM - 2x16GB DDR4 3600MHz - 15k
GPU - Asus/MSI/Zotac/Gigabyte RTX 3060Ti - 45k** (Future purchase)
M.2 SSD - Kingston A2000/WD SN550 1TB - 9.5k
HDD - WD/Seagate 4x4TB - 4*8.2k - 32.8k
PSU - Antec HCG750 80+ Gold - 7.5k
Cabinet - Lian Li 215 or other mid tower ATX - 6k (can vary)
Monitor - Acer Nitro XV272U 27″ 1440p 144Hz Freesync - 25k
Total - 204.8k
Check primeabgb, mdcomputers, theitdepot, vedant computers, onlyssd (online stores) for PC parts at a good price. Some parts have such low prices on amazon during sales as well.
*Cooler - Noctua NH D15 - 8.5k
or Lian Li Galahad 240mm AIO - 9.5k
or CM Hyper 212 Black - 4k
**3060Ti is good for 1440p gaming IMO but as I said, prices are insane right now & even RTX 3060 is like 55k & its performance is similar to the old RTX 2070S which went for as low as 40k at times. Contact RPTech to be added to the queue for RTX 3060Ti FE (35k) & 3070 FE (45k). If you are lucky enough, might get it. If you are unsure about gaming, just hold out with your 970.
