use VCD Gear to extract mpg data from d dat file
wen usin VCD Gear ensure dat u enable Fix mpeg error option
den ue VirtualDubMod with d necessary codec using which u wanna encode d file
den in VirtualDubMod Options>Sync to sound and Option>Drop frames when behind
to be enabled 2 keep AV in sync
