please help me with hdd problem
p_roy
i am trying to upgrade my PC and bought a Seagate Barracuda 320 Gb SATA drive. now the problem is that my old drive is a Seagate IDE drive (80 Gb). i would like to keep it as a secondary drive and the barracuda as the primary one. i have a Asus 5ld2-vm mobo.
i am really confused how to go about it and the mobo bios settings.
can anyone lease help a total novice in this?
thanks in advance.
slugger
Banned
use d jumper setting 2 make d SATA ur primary master and d 80 GB 1 d slave
d jumpers pins r like d pins not unlike d pins of d IDE connector but only 6 in no dey r placed right next to e data cable slot
d jumper is a small teeny weeny cap like thingy dat is used 2 establsih contact between 2 jumper pins
*www.pcguide.com/ref/hdd/op/z_000481connectors.jpg
d img shud give u a fair idea of wat 2 look 4 wen looking 4 a jumper
d actual thingy might wary a little
