Need suggestion for Router for my 200mbps BSNL connection
Maniparet
I have a BSNL fiber connection that is of 200 mbps speed. However the default modem provided gives only maximum around 100mbps via wifi but almost full via LAN (around 180 and 190). So i need suggestion for buying a router that can provide the max speed without limiting at 100mps via wifi. BSNL customer care just suggested buying a dual band router. Checking on amazon i saw hell lot of options and i really don't know which one will be good. Attached is the image of the BSNL modem i am using.
Buy a WiFi 5GHz or AC router.
Something like this will suffice:
TP-Link Archer C6 Gigabit MU-MIMO Wireless Router, Dual Band 1200 Mbps Wi-Fi Speed, 5 Gigabit Ports, 4 External Antennas and 1 Internal Antenna WiFi Coverage with Access Point Mode, Qualcomm Chipset - Buy TP-Link Archer C6 Gigabit MU-MIMO Wireless Router, Dual Band 1200 Mbps Wi-Fi Speed, 5 Gigabit Ports, 4 External Antennas and 1 Internal Antenna WiFi Coverage with Access Point Mode, Qualcomm Chipset Online at Low Price in India - Amazon.in
Has multiple 1000Mbps LAN ports to be futureproof.
M
Maniparet
Thanks for the suggestion. Will check this out. :smile:
