stallion316
Hello,
Currently I am having dell u2515h 2k monitor.. I am planning to get a 1080p secondary monitor.. mainly use them for social site yt videos etc..
I need some monitor suggestions, (budget oriented) that will go well with my current monitor..The size of the bezel should be equal....to the current one..
Need your opinions and suggestion..
1. Budget?
Around 15k -22k max
2. Display type and size?
i am currently having dell u2515h, so i guess 25 inch.
3. What will the TV/monitor be used for primarily?
This will be my secondary monitor..Mainly be using it for Social sites, yt videos and occasional gaming
4. Types and number of ports required?
dvi, hdmi, dp(optional)
5. Preferred choice of brand?
Anything with ips panel, 60hz that will match the the height of my current u2515, so that it will be in same level..
*www.amazon.in/Dell-60-96-Ultra-Bez...d=1541132232&sr=8-6&keywords=ips+monitor+thin
Thanks...
Regards..
1. Budget?
Around 15k -22k max
Thanks...
Regards..
