**Need Help**Plz Help me
jeetest
hey i m using kobian PI845GLM and i want to buy new Graphic card plz help me plzzzz:confused::confused::confused::confused::confused::confused::confused::confused:
some detail about my pc
General Information :
Manufacturer : KOBIAN
Product : PI845GLM
Version : 1.0
Serial Number : 00000000
Support MP : Yes, 1 CPU(s)
Version MPS : 1.4
Chassis Information :
Type : Desktop
Version : 1.0
Asset : 0123ABC
Sensor Information :
Monitoring Chip : Winbond W83637HF
Slots Information :
Slot PCI : In Use (32-bit) 3.3v, Shared Slot Opening
Slot PCI : Available (32-bit) 3.3v, Shared Slot Opening
External Connectors :
SSA SCSI : DB25 male
Internal Connectors :
USB : Mini Centronics
System Configuration Options :
Option #1 : System Management BIOS from Atlanta
Option #2 : SMBIOS from AMI
hey can i use nvidia 6600 ???
??????? no ans
debsuvra
is NOT a PC/Mac
Why did u use such gaudy fonts here ? If you think that it will attract more people in the forum to solve your problem, then you are WRONG. Please use general formatting in the future.
And for your question, I think your motherboard does not have a AGP slot. So you cannot add a gfx card from nVidia GeForce 6xxx family. Search for PCI based cards if they are available.
madmax_tt
P1845GLM have AGP slot....but before using AGP card u might need to update your bios.......
i usd to have those boards and GeForce FX 5200 AGP card back in 2005. i cannot use the card until i update the board bios...
nvidia
-----ATi-----
Edit your post and reduce the font size. That font size wont attract more people in the forum. It will drive them away from this thread:mad:
Btw, you have posted the same question HERE
sg1
On a quest for knowledge!
Re: MOD/ADMIN!!!
Could a staff member please reduce the size of the font in the thread starter:) my eyeballs nearly fell out!!!:rolleyes:
