Need Advice on Best budjet Cabinet for pc running 22/7 without ac
Sinja
The Demun
hello friends
im using an old cabinet for ma pc with 2 fans and 1 onf them does not work properly. im planing on buying a new cabinet.
my hardware
1gb ram ( upgrading to 2 gb ram)
intem 915 mobo
-intel 3.0 Ghz Pentium processor
-- gettting xfx 8600GT
my pc will run 22/7 running games and applications. wat sort of cabinet should i use can u suggest budjet cabinet.
zyberboy
dá ûnrêäl Kiñg
go for zebronics peace cabinet with one side ,top and 120mm rear led fans. Cost around 1800Rs without smps
*www.zebronics.net/gamingcabin.asp
