Need a cabinet for 5000 or less.
Gen.Libeb
[SOLVED] Need a cabinet for 5000 or less.
I already have a cabinet now but it won't fit in graphics card larger than 9in. So I am out looking for an ATX cabinet that'll fit in larger sized GPU's.
I also need to fit in 3 HDs + DVD drive.
Don't have much knowledge on this. I've only seen Cooler Master HAF 912, It seems nice but I'm not sure of the size.
I don't really want to go over budget because I also need to buy a graphics card.
*www.digit.in/forum/graphic-cards/186957-buying-new-graphics-card-gtx-760-better.html
Thanks
G
Gen.Libeb
Thanks,
The CM N500 does looks really nice.
But I'm putting this on hold for now. I'll first buy a graphics card, If it fits in my existing cabinet, then I don't really need a case anytime soon otherwise I'll have to consider these options.
