Monitor Resolution Problem
static_x
I installed my new LCD panel AOC F22 yesterday. After installing all the drivers it showed the resolution as 1920x1080 perfectly (DVI). Now after this now whenever i'm restarting my system everytime it goes back to 640x480 resolution and everytime i 've to select the 1920x1080 resoltuion. I've re-installed all the drivers (of Mobo as well as monitor) twice but the same problem is coming. I cant understand what the problem is. Please help me out!!!:sad:
desiibond
Bond, Desi Bond!
hmm. what is the motherboard and graphics card that you are using? And are you using DVI cable or VGA cable?
static_x
static_x
I contacted my local dealer here and he said that I've to install a separate Graphics Card to overcome this problem. Is that true?
static_x
static_x
that's bullshit. Try new Catalyst 9.6 that is made available today.
Thanks desiibond :lol:
Installed Catalyst 9.6 and my problem is solved. Earlier the display driver was showing the release date as October 2008 and now its 15.6.2009 and the resolution is back to 1920x1080. :lol:
I also upgraded the chipset drivers from the gigabyte website.
I later found that the DVD provided with the Mobo was for GA-MA790GP-UD3H and mine is 790GP-UD4H. May be that could be the reason for it. Anyways, the problem is solved now.
Thanks once again.:)
desiibond
Bond, Desi Bond!
welcome. glad to hear that the problem is solved. You better get the correct DVD from gigabyte. report to the dealer who sold you the mobo.
