Monitor Problem
winzip
Hi all,
I have suddenly changed the position of my computer table and after I switched my computer on, I found the monitor becoming skyish in color. After some time the skyish background went and everything became OK. The same thing happened 2-3 days and after that the monitor color permanently became skyish; and till now it is in this state.
I have Samsung 15" monitor (Samtron 56V) and it is about 3 years old.
Is it the problem of the motherboard (ie video card) or the monitor itself.
Please suggest.
ilugd
Beware of the innocent
check if the monitor is too near to any magnetic area (electromagnetic field???) etc. I mean, huge speakers, radio equipment or magnets. Sometimes even keeping a cellphone near the monitor changes the color.
ayush_chh
may be due to faulty pic tube......(in addition to deathvirus_me's reply)
we also had a samsung's samtron in my dad's office......it started showing greenish display...'twas due to faulty pic tube.
janitha
Since it started after moving position, it is more likely that degaussing will solve the problem. But still check the cables.
W
winzip
786 said:
I was having the same prob. You can cheak the cable.
I also think that it is the display cable responsible for all this. But I have checked the display jack and tightened it repeatedly. But of no good.
I dont know if there is an internal problem of the display cord.
@winzip
It happens to be an internal prob. Get our Mnitor checked from your nearest servicer. I too have the same prob. till this date.
Look here.
R
rahul_becks23
Guest
check 4 any electromagnetic influence from devices like UPS.
is the ups too close to the display.
