Monitor 24inch vs CPU cooler+monitor 22inch
ratedrsuperstar
The Sexy Beast
for a budget of 12k what would be ideal? afaik the benq 24inch comes for 11.5k
or should i buy a 22inch (recommend a model) + Arctic Cooling Freezer 7 Pro Rev2
i need a 1080p monitor.is running at 1080p on 22inches the same as running 1024x768 on a 15inch??
current config
intel e7200 OCed to 3.1Ghz
abit ip35-e mobo
Gigabyte 9600GSO 384mb
XTerminator
Welbeck fan :D
*reviews.cnet.com/lcd-monitors/benq-v2400w/4505-3174_7-32906371.html
i fancy samsung t240hd.though 2400w ftw as well.
also check these mfers:
*reviews.cnet.com/lcd-monitors/dell-professional-p2210/4505-3174_7-33656461.html?tag=also
and
*reviews.cnet.com/lcd-monitors/hp-2009m/4505-3174_7-33557215.html?tag=also
for its price
asingh
current config
abit ip35-e mobo
Will you game....?..GPU...?
