Moisture problem on GPU, Proc and other parts during monsoon
jetboy
Hey Guys...does anyone have solution for moisture problem which tend to arise during monsoon season ??
I remember one of my friend had had one CM cabinet with 3 fans..it would still increase the temperature within the cabinet and give a red indicator in the temp section on the graphics card + after the machine gets settled down moisture settling becomes a BIG PROBLEM. Dust + moisture actually ruined his GPU.
Any ideas on how to avoid that problem..Certainly no ones wants there expensive things getting ruined due to moisture problems?
What are the steps one would take to avoid moisture problem?
mithun_mrg
Just get come silica gel from a chemical store make a small pouch with cotton fabric Gel inside put the put the poutch inside ur case ideally make 2 put one on top other on bottom
BTW in HCL pc pacaging they give a big pouch ask ur local dealer if u can get 2
