LED monitor with VESA mount
a2mn2002
keen to learn..
Guys my new room is ready & paint work is going on , i want a -
1. 22-23" led monitor
2. HDMI
3. VESA mount
to hang it & make the room look good @ 15k.
Plz suggest something.
Is anyboay there ?
Saahib
Just to add here, Vesa is supported by all Monitors, all you need to ask for VESA mount so.. buy any monitor which you like.. VESA mount can be added later !
not all monitors....
if monitor has five Screw holes then its VESA else not VESA
@a2mn2002: if u want to hang it on wall then do buy a slim monitor for
beauty....slim monitors are available in DELL,ACER,Samsung
A
a2mn2002
keen to learn..
thnx mate!
Yes i want to hang the monitor on wall by any means.
Plz suggest me a particular model of slim monitor.
thnx mate!
I have Acer S231HL which is a slim monitor with wallmount mount...
has nice black borders *computergadgetreview.com/wp-content/uploads/2010/07/Acer-S1-Series-Ultra-Thin-LED-Displays.jpg
or u can opt for any other good looking brands such as DELL or Samsung
A
a2mn2002
keen to learn..
mate plz find something which can be hanged on wall from sam / dell / lg coz i am not aware of that.
Saahib
Well, I have used so many LCDs.. still not able to spot any single LCD without VESA mount support.. btw, there are 4 holes requried for VESA.. I was also not able to spot any monitor with 5 holes for VESA :p .. :)
