yes that's right 1080p is not for 27inch.. will take 1080p 24inch now..*www.amazon.in/Acer-Nitro-VG270P-Gaming-Monitor/dp/B07VZ5TWVV/
This might be the only decent option under 18k. Many people say that 1080p isn't sharp enough for a 27" monitor. I have a 24" 1080p & I'm fine with it (Acer VG240Yp).
In case you see LG 27GL650F on sale for close to 18k, that is the best option.
Look at Acer VG240Yp (or Ys) for under 14k or MSI G241 for 15-16k.yes that's right 1080p is not for 27inch.. will take 1080p 24inch now..
okLook at Acer VG240Yp (or Ys) for under 14k or MSI G241 for 15-16k.
Both are IPS LCD only, MSI one has a higher colour gamut (125% sRGB vs 100% sRGB of Acer).ok
acer one is led but msi one is lcd
its mentioend lcd on amazon - *www.amazon.in/MSI-Optix-G241-24-Gaming-Monitor/dp/B08B8LBM3S?th=1Both are IPS LCD only, MSI one has a higher colour gamut (125% sRGB vs 100% sRGB of Acer).
The only true LED monitor are OLED monitors & those aren't available in India yet & definitely out of your budget. Otherwise most monitors are some type of LCD only with LEDs used for backlight. Both the monitors I suggested are IPS LCD ones.its mentioend lcd on amazon - Amazon.in: Buy MSI Optix G241-24 inch IPS Gaming Monitor – Full HD - 144hz Refresh Rate - 1ms Response time – AMD Freeync for Esports Online at Low Prices in India | MSI Reviews & Ratings
ok. thanks.The only true LED monitor are OLED monitors & those aren't available in India yet & definitely out of your budget. Otherwise most monitors are some type of LCD only with LEDs used for backlight. Both the monitors I suggested are IPS LCD ones.
Just search on Google a bit.
Avoid, TN panel. TN panels look bad because of poor colour reproduction & contrast ratio. Avoid cheap VA panels as well. I personally use Acer VG240Yp.*www.amazon.in/LG-Ultragear-Native-...dime01-21&ascsubtag=20210527cly51gi15sak&th=1what abt this one ?
kAvoid, TN panel. TN panels look bad because of poor colour reproduction & contrast ratio. Avoid cheap VA panels as well. I personally use Acer VG240Yp.
