ms_karthik
I have a 140 GB Hard Disk (60+80) Seagate.
I have six partitions. I have a separate partition of 6 GB just for Windows.
I am running Windows XP Pro SP2 with all the latest patches and updates.
Of late, my C: drive which resides the Windows is out of space. Always it says there is no space. I followed Digit's advice to allocate a separate partition for Windows of 6 GB. But space is not enough. I even moved My Documents from my C: drive but to no avail.
Now i have only 142 MB free space in C: Drive. Somehow the system tends to be stable. I even disabled System Restore and reduced the space for Temp Internet files to minimum. Please tell me what to do.
Can I increase my C: drive space without losing any data.
My system config (may be of any use)
AMD Athlon 2000+
1 GB RAM (two 512 sticks) DDR
nVidia GeForce FX5200 (MSI)
140 GB HDD (60+80)
LG CD Writer
LG DVD ROM
These things run in background
Nortan Antivirus 2004
Microsoft AntiSpyware
Google Desktop Search
I even changed the Virtual Page Memory from my C: Drive
I also would like to know how much Virtual Memory is suggested for 1GB RAM
Thanks
AMD Athlon 2000+
140 GB HDD (60+80)
LG CD Writer
LG DVD ROM
Thanks
