Shadowfax2009
Wandering around
Hi all great guys. You all are really helpful. Just reading the threads here have solved many of my confusion.
I am building an i7 rig. I have finalized on the most things.
MB= EVGA X58 SLI from Phoenix
GFX = 4890 Powercolour from TE
Ram = OCZ/ Gskill 6gb 1600 or (If God is merciful) 1800
Cabinet = I wanted to be a little miserly and go for something around the 2K - 3K range. Will Coolermaster Elite suffice.... Suggest plz.
PSU = Dont really know. Need some serious help. Currently I will not be doing SLI. So I need to run only a GTX285 (After a year might give the PSU to the home Media center, I am currently at Delhi). Tagan 800? Coolermaster Extreme power 600 - 700 ? Or do I need A Coolermaster Real power 750 - 850?
SMPS = I am very averse to spending 12000 - 17000 on a pure sine wave APC now. What should I buy? Wont the normal APCs Do. MAx I can spend is 8000/ otherwise I will have to settle for UD3 Motherboard ... Which doesnt make any sense as Mboard will be the only thing of the platform that will not be upgraded in the long run.
Pls suggest some Genuine INDIAN Cheappo Ideas
